Not activated properly
  • Not activated properly
    Stuck on finding custom devicesClick image for larger version
    The solution was shown as is. Please make sure there is nothing installed on your PC that may prevent our software from connecting to the internet. Check the firewall settings, internet connection settings.
    Also, it is recommended for you to check the windows Hosts file to see if there are any records related to disc-soft.com domain name. If there are any, please make sure to delete them.
