Hey! I tried looking for posts about this. I'm just started to try out reWASD. So far everything is working except the mouse movements. It works in matches but not in the main menu, the cursor does not move with the thumbstick so I cannot move to select anything with my controller.
Mapped mouse movements to controller, not working
Hello. to better understand your problem, we need to see your config. Could you send screenshots of your device settings, or config as a file?
All the configs are stored here C:\Users\Public\Documents\reWASD\Profiles. The name of the profile (Game name usually, on the top-right corner or reWASD) corresponds the folder name, and the name of a config (on the top-left of reWASD screen) in the name of a file you should look for in that folder.
