I heard it is possible for Adaptive Triggers to work through Remote play just through normal USB without reWASD. So I was wondering if it was possible through Bluetooth and reWASD. If it isn't, is it ever possible for this feature to appear?
Does reWASD remote play allow Dualsense Adaptive Triggers via Bluetooth?
The simple answer is no
reWASD creates a virtual DS4 controller instead of any other supported gamepad you use. Our DS4 controller emulates the USB connection which is required for PS Now for example. Adaptive Triggers are available for those who use DualSense, but our virtual controller is DS4. We do have plans to create a virtual DualSense controller, but at the moment, I can't tell you any approximate release dates, because it is a pretty big task.
