Basically, I want to play Ratchet and Clank Future: A Crack in Time via PS Now, but I can't access the map as it requires a left touchpad click. The only touchpad click option I have in reWASD is a center click. Any help would be appreciated.
How to map left touchpad click for PS Now
This topic is closed.
Hey there! Pretty funny solution, but if it works for you that is greatOriginally Posted by Nintenbro View PostUnfortunately, I don't own the combo feature. However, I instead separately mapped click and left touch, and simultaneously pressing them worked. Thanks a million!
In case you want to check the steps from RAM Stealer , let us know, we could add a few trial days for you.
