Someone know if I can play r6s with mouse and keyboard with remote Play of PS4? I tried but it doesn't work, I don't know why
Remote Play
Hey! Pick a group, then I'd suggest to try the basic PS4 Remote Play config you have in reWASD (the default one) Pick the menu in the top right, choose PS4 Remote Play, and press Apply. Your mouse will lock, because we mute native input and assign right stick to it. To get mouse back, press Left Windows button. To turn remap off completely, press Ctrl+Alt+Del combo on your keyboard. After remap is ON, launch Remote Play.
You can also check this video guide that describes the steps RAM Stealer sent you previously.
