Need help with recoli control
  • Need help with recoli control
    Can anyone help me with the recoli control? I playing Warzone
    First thing — I am not sure if your config is perfectly well made. You do not have "unmaps" for the mouse buttons, and so the game should be constantly switching between inputs with such setup. Please ensure that all the keys and buttons you use have unmap added, so the native device behavior is muted.
    As for the recoil control, you can adjust it using Combo and adding relative stick deflections that correspond with the weapon type you use. You can find more details here.
      This one is configured perfectly, read the description on game and mouse settings.. If you got a question ask..
        Thank you for sharing! Could you please also post it to our Community?
        You can share the config to the Community from the app itself, just click Share icon near the config's name.
