I am using full purchased rewasd.
So I am using shortcut on the game also and I wanna add hold key to the shortcut.
For example, Left (Hold) + Square+Triangle. That mean, I will pres to the keft key and hold then press to square and triangle. Is it possible ?
Thx
Thx
