Hi, i'm new to rewasd so please, don't be too rude!
someone can please explain me (step by step would be nice) how to setup the nav controller to work via bluetooth? can i use pc's internal chip or i need an external dongle dedicated? (i'm not interested in using more Bt device at the same time)
also, i need the usb cable only the firt time, right?
if i succed what i've to do then? i've tried with a standard xbox one controller (Sony nav is on his way at the moment
) but when i try to play in warzone there's a continuos switch beetwen m&k and controller settings... thanks in advance
