Installer not running
  • Installer not running
    When trying to run the reWASD installer nothing opens, and in taskmanager windows problem reporting appears.
    When checking up on windows event viewer two distinct errors appear, which are attached to the topic.
    What's weird is that the same installer works perfectly on other computers, this one is fully operational, checked for all types of errors, updated to most recent update but still nothing.
    1.txt
    2.txt
    Hey
    Please check which .NET version you have. Here are the steps:
    1. Run Command Promt as Administrator (type cmd in Windows Search bar)
    2. Paste this string: reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\full" /v version
    3. Check Version value or send me the screenshot of what you got
      Hey
      Thanks so much for responding!
      I've previously checked my .NET version and confirmed it to be the correct one, which made me kinda weirded out by this issue.
      I've disabled my antivirus, other apps that might be interfering with the installer.
      Command Prompt result:
        It's all right here. We'll be looking at your logs with the team in the coming days. We are sorry that you will have to wait.
          Thank you for the explicit information. As far as we can see from logs, there is some issue with the .NET framework which can't unpack some resources required during the installation.
          At the moment, I would ask you to try this official tool to repair .NET and hope it may help in your case. We will also try to catch and resolve this issue from our side, but it would be a tricky thing because we can't reproduce it at all.
            Thanks for answering!
            When i run the official tool for repairing it says: "The tool is unable to resolve the installation issue on your computer".
            Although before it says that changes were made? The changes were: Reregister Windows Installer service and Restar Windows Installer service.
            Basically nothing happens except it creates a .cab file in my desktop with a bunch of logs.
            By the way, thanks so much for helping out!
              You can try looking for ways to fix .NET in the internet. Here are some helpful links that may help you. If none of this solves your problem, you may need to clean install Windows OS. We are also trying to reproduce this problem from our side, but as already written above, this is very difficult.
                I'll look into the solutions you've proposed, thanks so much!
                From what I gather it's from installing old-ish disc games that installed?/modified? .NET on their own (which I guess pirated games fit into the same description), not sure though.
                Thanks a lot for helping out!
                  Always glad to help!
