DbD stutters when turbo “A” and “D” mapping
  • DbD stutters when turbo “A” and “D” mapping
    Hi, i’m having this issue all of the sudden. I configured rewasd so when i hold the left d-pad button, it would do left and right turbo to “auto struggle” in Dead by Daylight (to try and escape the killer while he’s carrying you to a hook). It used to work like a charm, then one day it just started to hog the game and stutter all the way, failing to input the keys correctly.
    i have not made any major changes on my laptop. I could use some help to fix this please, thanks in advance!
    specs: Asus X555U laptop, Geforce 940m, 12gb ram, Intel Core i7 6500U, Samsung 860 1TB SSD, Windows 10 Pro 64, Xbox One Controller.
    I play with Razer Cortex. Tested both with and without Cortex, same problem.
    Hello there!
    We would appreciate it if you can provide us with the screenshot of a config or a config itself.
        So you're trying to just drag the stick left and right fast? I think you're missing a pause between the two stick nodes. And it probably should be of the same value as the [Turbo].
          Yessir, i just fixed it by adding those pauses. Thanks!
