I play Mortal Kombat 11. I am using the recording feature to record macros for the combo strings. I am here to ask what is the best way to record combo strings. Presently, I am recording one seriesat a time which is quite a lengthy process as i have to figure out the time between the actions. Here is an example - Dragon's Breath requre this D+K KKK. Normally i record that first then go back to the game and see if it worked. Once verified i go to the second part of the the combo .lets say "The time has come" which is " IJI: I record that by itself and check to see if it works. My next step it to put those 2 together manually and figure out the timing between the two combos to get them to string together.
I am not good enough via keyboard to record a complete combo and record it using the keyboard for mapping. I wiah there was a way i could manually type in the combo string and make it work. Does anyone have a easier way for me to do this?
