Hi all,
I'm new here and wanted to see what the possibilities are with your software for use with the PS4 and Azeron and/or a Xim Apex.
I purchased the license already and will be keeping it either way as I also play on PC, but what I'm currently trying to do is use ReWASD to remap the Azeron to have turbo and/or key combos for use on the PS4. Although I've seen posts saying that it's possible to use ReWASD with XIM and also using the Azeron with ReWASD, I haven't had much luck doing using the 3 together, or keeping remaps when plugging into the PS4.
Is this possible with my current hardware, or even at all?
Thanks in advance
Thanks in advance
