Hi all
​​​​​​Been using ReWASD for the past year or so, great piece of software, however the most recent update has a bug which basically reverses the accelerator and brake pedals of the G920/G92/G932 when it is installed.
I noticed last week when I went to play F1 2020 and the car wouldn't move and kept reversing etc.
Looking in G Hub, the pedals are inverted (so full throttle/brake when not pressing them, pressing them does the opposite)
Even after stopping reWASD processes it still happens. Once I uninstalled it the pedals are working normally again. Would be great if you could look into this!
