hi reWASD,
first & foremost, I'd like to thank you all again for your hard work on developing this software. I have been enjoying my games ever since full gyro support came out.
my questions are related to joycons & Playstation 4 & 5.
I have a strong Bluetooth adapter in my PC which works great when I use it on PC; however, when I use my joycons on my PS4 via External Device, there is huge input delay both on my analog buttons/sticks and gyro. looking it up, I found that the PS4 uses Bluetooth 2.1 which is very old, and I would understand all the delay if this is the root cause of it. PS5 supposedly uses Bluetooth 5.1 which is the same version as my card on PC.
my questions are: is the input delay caused by the old PS4 Bluetooth version and would it be alleviated if I used my joycons on PS5 instead? I actually don't have a PS5 yet and can't test this myself, but I have been thinking about making the jump if this will fix the problem.
thanks again as always for your insight and wonderful product!
