i need help using controller on valorant, i used a config and everything works but the aim, and my mouse isnt recognized on rewasd, (G502)
Valorant works with only one keyboard and mouse input. In order the game could see the input from the stick, the mappings should be emulated on behalf of your physical devices. Right now, this behavior only affects the mouse, but you can choose both to be sure that everything works perfectly with this or upcoming game’s versions.
So, to resolve the issue you need the following steps:
- Ensure that you are using reWASD 5.7.1 version
- Go to Preferences (gear icon at the bottom right) -> Input Devices tab
- Choose the physical devices (1) and click Apply (2):
- Apply your Valorant config (or choose one of those we have in our Community.
