Is there anyway to cancel key combos quickly, I use combos for fighter games and if you miss your combo, rewasd still preforms it.
Cancel Key Combos?
All running [Combo] can be stopped with [View/Back/Share/Minus]+[Menu/Start/Options/Plus]+[LB/L1/L]+[RB/R1/R] shortcut.
You can add a big pause at the end of your [Combo] and set a [Turbo] flag to it, so the [Combo] would stop once you release the remapped button. Though that will require you to hold the button instead of just tapping it for [Combo] to work.
you're a life saver. thanks a bunchOriginally Posted by Shion View PostAll running [Combo] can be stopped with [View/Back/Share/Minus]+[Menu/Start/Options/Plus]+[LB/L1/L]+[RB/R1/R] shortcut.
- Likes 1
