Recoil for warzone
  • Recoil for warzone
    Sorry am new using this program and i will gladly buy it but i just want to know if there is a way to to add a recoil control to cod warzone, i play with controller on pc, am new and i dont undestand how to use anything.
    It is possible to achieve by adding the key combo with a relative deflection, that will move the cursor to the opposite way of the recoil itself, in order to control it.
    Check this use case #20, this is exactly what you need
