Version 5.7.1
Installation
I downloaded version 5.7.1 & tried to install the software. (disabled malwarebytes)
1. When clicking on the configure options button on the installer, the installer crashed.
2. i was only able to install the software without clicking on the configure options.
Running the Software
After restarting my PC, reWASD came up on my taskbar below, and was able to connect to my elite 2 controller.
however, i was not able to config anything
1. upon right clicking on the taskbar and clicking 'Open reWASD' the loading button came up and did not start the software.
2. upon going to the installation folder, i was not able to open any of the software
- reWASD.exe
- reWASDEngine.exe
- uninst.exe
Uninstall
I then tried to uninstall the software, again, couldn't uininstall the software via 'add remove programs' or clicking on uninst.exe. I needed to go to cmd prompt to uninstall driver & installation
Version 5.7.0
so i tried to install 5.7.0, user making chances prompt, installer closes
Hope someone can help! Thanks
