I wonder if it is even possible to have one controller act as two different controllers using rewasd; for example, if I want to play as 1P and 2P and press A on my controller, it'd emulate that into two different controllers doing that for the game. Is that even possible? I tried researching, but I didn't find anyone talking about it.
Have one controller act as two different inputs (1P and 2P)
reWASD is able to remap a group of devices to a single virtual controller, keyboard and mouse. Remapping a single device to multiple virtual ones of the same type is not possible at the moment.
But, you can disable an option [Hide physical controller when virtual one is created] at [Preferences > Gamepads], and have every button and stick of your controller remapped to the same buttons and sticks of a virtual one, so once you apply the config you'll have our virtual controller mirror actions of your real one while both will be visible to the system. But for this to be of use your game must support both your actual and our virtual controllers.
