Steam
  • Steam
    I only recently made the jump from console to PC, greatly enjoying it thus far. But i have a lot to learn. One of those things is this program. I want to play a game I got on Steam (Dragon Age 2 if you want to know) I've already played it on Xbox, so i'd like to map those controls to the Xbox controller and be able to play that game on steam with that control set up. I found a configuration that does just that and i imported it, but I don't exactly know where to go from here. Any tips? Thanks
    Select a configuration from the list by clicking the top right menu and then apply it. Select a configuration from the list by clicking the top right menu and then apply it. When the config is applied, you can go into the game and check if everything works.
    You can learn more about the interface here.
