Hi everyone. First of all I want to talk with technical support because it seems like the program can not work.
problem:
I used the left analog stick to trigger simple combo (forward down back square) by moving stick to the left.
And it work perfect until one thing… When I press any button before this trigger it is going wrong. For example I press triangle and immediately move left stick to the left. What happened?
Mortal Kombat 11 have ingame input showing on the screen in training mode. And I see this: triangle forward down up up down up forward back up up back back up square square. Combo breaks by the program. It is not even combo, it is a simple special move program can not launch correctly.
It is not funny guys. What should I do?
problem:
