Estou a dias tentando usar o meu mouse como o right stick no warzone mas não da certo, estou tentando jogar pelo ps4 remote play mas não consigo mexer a mira, consigo mirar e atirar, mas não consigo mexer a mira para esquer/direita ou /cima/baixo, o que devo fazer?
Não consigo usar o mouse como right stick
To remap mouse to a stick of a virtual controller you need to have [Advanced mapping] feature. A trial period of 3 days is available for it: click on a [Key] icon at the right bottom corner, select [Advanced mapping] tab and click on the [Try] button to activate it.
Só vai funcionar se eu tiver essa extensão?Originally Posted by Shion View PostTo remap mouse to a stick of a virtual controller you need to have [Advanced mapping] feature. A trial period of 3 days is available for it: click on a [Key] icon at the right bottom corner, select [Advanced mapping] tab and click on the [Try] button to activate it.
Aumentei a deadzone mas meu personagem ainda continua girando, coloquei a do warzone no maximo e mesmo assim continuaOriginally Posted by Shion View PostTry increasing deadzone value in game or at [Advanced settings] of mouse-to-stick mapping. Gray area of [X axis] would be the deadzone.
Please remove the mappings from zones in mouse directions like I have here: https://recordit.co/MrVAMtjXjO
