Here's my config link with my ingame settings in the description:
I'm wondering if having 0 acceleration is a bad idea. As well as max dead-zones. It feels okay, but I want to try to make it so I can do smaller aim adjustments, because at farther distances its difficult.
The only other config I saw was this one:
The response curve is similar, with higher sensitivity's. but for some reason the low on the deflection is at 100 which makes me turn suuuper slow even at max in game sensitivity, not sure what his in game settings would be to prevent this.
