Hey guys, my first post here.
I've scoured the forums but couldn't find anything relating to this query
I'd like to map my Xbox controller's Xbox button to control my Spotify.
MAPPING:
[Shift 0]
Current behavior: When I try to adjust the volume by holding (Xbox button) + (D-pad Up), it pauses my music as well as adjusts the volume.
Desired behavior: Ideally I'd like [Shift 1] to activate on a delayed hold so that reWASD is able to differentiate between when I'd like to use the press activator/double press activator and holding down [Shift 1]
MAPPING:
[Shift 0]
(Xbox button)
press activator: Play/Pause music
hold activator: N/A
double press activator: Open Spotify
[Shift 1]hold activator: N/A
(Xbox button)
:Use as Shift modifier:
(D-pad Up)
press activator: Volume up
(D-pad Down)
press activator: Volume down
