Toggle LEFT/RIGHT swap?
  • Toggle LEFT/RIGHT swap?
    Hi, I'm using reWasd to set some combos in fighting games, but the problem is when the combo has directional inputs (for example, DOWN, BACK, A or BACK-FORWARD, X, etc) My macro will only work when I face one direction, but if I'm facing the opposite direction, I need to swap the left and right in my combo. Is there a way to do that?
    reWASD cannot determine what actions take place in the game. In your case, you can create another similar combo, where the movements will be performed in the other direction.
      Thank for the reply. If I make two separate macros (one for left, one for right) is there a way to to quickly toggle between them using the same bind? Or I must to use different buttons?
        You can try creating a [Shift layer] and assigning the second combo in it to the same button.
          Perfect, thank you!
