Hi!
Newbie here. Every time I try to either launch, re-install or uninstall REWASD, it crashes with the message "REWASD has stopped working". I suspect this is a NET Framework related issue. Any help would be greatly appreciated!! Here's my Event Viewer log:
Log Name: Application
Source: Application Error
Date: 09/25/2021 3:08:06 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP
Description:
Faulting application name: reWASD581-4666.exe, version: 5.8.1.4666, time stamp: 0x6139f709
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1202, time stamp: 0x448a4f5d
Exception code: 0xe0434352
Fault offset: 0x0012b5b2
Faulting process id: 0x77d0
Faulting application start time: 0x01d7b240a60e66e0
Faulting application path: C:\Users\jcste\Downloads\reWASD581-4666.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: b4addf91-bc0d-4c6b-a013-8bdbcad770ad
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2021-09-25T19:08:06.8117536Z" />
<EventRecordID>55618</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>DESKTOP</Computer>
<Security />
</System>
<EventData>
<Data>reWASD581-4666.exe</Data>
<Data>5.8.1.4666</Data>
<Data>6139f709</Data>
<Data>KERNELBASE.dll</Data>
<Data>10.0.19041.1202</Data>
<Data>448a4f5d</Data>
<Data>e0434352</Data>
<Data>0012b5b2</Data>
<Data>77d0</Data>
<Data>01d7b240a60e66e0</Data>
<Data>C:\Users\jcste\Downloads\reWASD581-4666.exe</Data>
<Data>C:\WINDOWS\System32\KERNELBASE.dll</Data>
<Data>b4addf91-bc0d-4c6b-a013-8bdbcad770ad</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Event ID: 1000
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
<EventData>
<Data>77d0</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Source: .NET Runtime
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP
Description:
Application: reWASD581-4666.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ArithmeticException
Exception Info: System.OverflowException
at System.Windows.Media.Imaging.ColorConvertedBitmap. FinalizeCreation()
at System.Windows.Media.Imaging.ColorConvertedBitmap. .ctor(System.Windows.Media.Imaging.BitmapSource, System.Windows.Media.ColorContext, System.Windows.Media.ColorContext, System.Windows.Media.PixelFormat)
at System.Windows.Media.Imaging.BitmapSource.CreateCa chedBitmap(System.Windows.Media.Imaging.BitmapFram e, System.Windows.Media.Imaging.BitmapSourceSafeMILHa ndle, System.Windows.Media.Imaging.BitmapCreateOptions, System.Windows.Media.Imaging.BitmapCacheOption, System.Windows.Media.Imaging.BitmapPalette)
at System.Windows.Media.Imaging.BitmapFrameDecode.Fin alizeCreation()
at System.Windows.Media.Imaging.BitmapFrameDecode..ct or(Int32, System.Windows.Media.Imaging.BitmapCreateOptions, System.Windows.Media.Imaging.BitmapCacheOption, System.Windows.Media.Imaging.BitmapDecoder)
at System.Windows.Media.Imaging.BitmapDecoder.SetupFr ames(System.Windows.Media.Imaging.BitmapDecoder, System.Collections.ObjectModel.ReadOnlyCollection` 1<System.Windows.Media.Imaging.BitmapFrame>)
at System.Windows.Media.Imaging.BitmapDecoder.get_Fra mes()
at System.Windows.Media.Imaging.BitmapFrame.CreateFro mUriOrStream(System.Uri, System.Uri, System.IO.Stream, System.Windows.Media.Imaging.BitmapCreateOptions, System.Windows.Media.Imaging.BitmapCacheOption, System.Net.Cache.RequestCachePolicy)
at System.Windows.Media.ImageSourceConverter.ConvertF rom(System.ComponentModel.ITypeDescriptorContext, System.Globalization.CultureInfo, System.Object)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateOb jectWithTypeConverter(MS.Internal.Xaml.ServiceProv iderContext, System.Xaml.Schema.XamlValueConverter`1<System.Com ponentModel.TypeConverter>, System.Object)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateFr omValue(MS.Internal.Xaml.ServiceProviderContext, System.Xaml.Schema.XamlValueConverter`1<System.Com ponentModel.TypeConverter>, System.Object, System.Xaml.XamlMember)
at System.Xaml.XamlObjectWriter.Logic_CreateFromValue (MS.Internal.Xaml.Context.ObjectWriterContext, System.Xaml.Schema.XamlValueConverter`1<System.Com ponentModel.TypeConverter>, System.Object, System.Xaml.XamlMember, System.String, MS.Internal.Xaml.Runtime.IAddLineInfo)
Exception Info: System.Windows.Markup.XamlParseException
at System.Windows.Markup.WpfXamlLoader.Load(System.Xa ml.XamlReader, System.Xaml.IXamlObjectWriterFactory, Boolean, System.Object, System.Xaml.XamlObjectWriterSettings, System.Uri)
at System.Windows.Markup.WpfXamlLoader.LoadDeferredCo ntent(System.Xaml.XamlReader, System.Xaml.IXamlObjectWriterFactory, Boolean, System.Object, System.Xaml.XamlObjectWriterSettings, System.Uri)
at System.Windows.ResourceDictionary.CreateObject(Sys tem.Windows.Baml2006.KeyRecord)
at System.Windows.ResourceDictionary.OnGettingValue(S ystem.Object, System.Object ByRef, Boolean ByRef)
at System.Windows.ResourceDictionary.OnGettingValuePr ivate(System.Object, System.Object ByRef, Boolean ByRef)
at System.Windows.ResourceDictionary.GetValueWithoutL ock(System.Object, Boolean ByRef)
at System.Windows.ResourceDictionary.GetValue(System. Object, Boolean ByRef)
at System.Windows.Application.TryFindResource(System. Object)
at RewasdWpfInstaller.SecondaryWindow.DTMessageBox..c tor(System.Windows.Window, System.String, System.String, System.Windows.MessageBoxButton, System.Windows.MessageBoxImage, System.String, Boolean, Double, System.Windows.MessageBoxResult)
at RewasdWpfInstaller.SecondaryWindow.DTMessageBox.Sh ow(System.Windows.Window, System.String, System.String, System.Windows.MessageBoxButton, System.Windows.MessageBoxImage, System.String, Boolean, Double, System.Windows.MessageBoxResult)
at RewasdWpfInstaller.Installer+<>c.<Install>b__31_1( )
at System.Windows.Threading.DispatcherOperation.Invok eDelegateCore()
at System.Windows.Threading.DispatcherOperation.Invok eImpl()
at System.Runtime.CompilerServices.TaskAwaiter.ThrowF orNonSuccess(System.Threading.Tasks.Task)
at System.Runtime.CompilerServices.TaskAwaiter.Handle NonSuccessAndDebuggerNotification(System.Threading .Tasks.Task)
at System.Windows.Threading.DispatcherOperation.Wait( System.TimeSpan)
at System.Windows.Threading.Dispatcher.InvokeImpl(Sys tem.Windows.Threading.DispatcherOperation, System.Threading.CancellationToken, System.TimeSpan)
at System.Windows.Threading.Dispatcher.Invoke(System. Action, System.Windows.Threading.DispatcherPriority, System.Threading.CancellationToken, System.TimeSpan)
at System.Windows.Threading.Dispatcher.Invoke(System. Action)
at RewasdWpfInstaller.Installer.Install(System.String )
at RewasdWpfInstaller.ViewModel.Pages.InstallPageVM.I nstallThread(System.String)
at RewasdWpfInstaller.ViewModel.Pages.InstallPageVM+< >c__DisplayClass9_0.<StartInstaller>b__0()
at System.Threading.ThreadHelper.ThreadStart_Context( System.Object)
at System.Threading.ExecutionContext.RunInternal(Syst em.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threa ding.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threa ding.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
Event Xml:
<System>
<Provider Name=".NET Runtime" />
<EventID Qualifiers="0">1026</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2021-09-25T19:08:06.7239884Z" />
<EventRecordID>55617</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>Application: reWASD581-4666.exe
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateOb jectWithTypeConverter(MS.Internal.Xaml.ServiceProv iderContext, System.Xaml.Schema.XamlValueConverter`1<System. ComponentModel.TypeConverter>, System.Object)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateFr omValue(MS.Internal.Xaml.ServiceProviderContext, System.Xaml.Schema.XamlValueConverter`1<System. ComponentModel.TypeConverter>, System.Object, System.Xaml.XamlMember)
at System.Xaml.XamlObjectWriter.Logic_CreateFromValue (MS.Internal.Xaml.Context.ObjectWriterContext, System.Xaml.Schema.XamlValueConverter`1<System. ComponentModel.TypeConverter>, System.Object, System.Xaml.XamlMember, System.String, MS.Internal.Xaml.Runtime.IAddLineInfo)
at RewasdWpfInstaller.Installer+<>c.<Install >b__31_1()
at RewasdWpfInstaller.ViewModel.Pages.InstallPageVM+& lt;>c__DisplayClass9_0.<StartInstaller>b_ _0()
</Data>
</EventData>
</Event>
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
<EventData>
</Data>
</EventData>
</Event>
