Apologies for the basic nature of this request but I'm quite new to reWASD.
I am trying to set up my Xbox elite controller to auto-sprint in Destiny. This means setting the left joystick to simulate being pressed when moved fully forward (I find pressing in and holding Xbox joysticks negatively affects my gaming and also really hurts my thumb after a while). I managed to do this.
The issue is that sometimes when moving forward while aiming in the game it disrupts my aim down sights because it thinks I want to run.
TLDR: I believe I could solve this if there was a way where full stick forward = press stick, UNLESS I am holding LT1 (which aims).
It is this last part I'm not sure if I can do - can I change the behaviour so that once I'm holding LT1, the stick behaves normally (even if full pressed forward)?
Thank you in advance.
