Была Ð¿Ñ€Ð¾Ð±Ð½Ð°Ñ Ð²ÐµÑ€ÑÐ¸Ñ Ð¿Ð¾Ð½Ñ€Ð°Ð²Ð¸Ð»Ð°ÑÑŒ решил купил лицензию (активировал код) объединил клавиатуру и мышь включаю конфиг работает только клавиатура или мышь одновременно взаимодейÑÑ‚Ð²Ð¸Ñ Ð² игре не работают в чем может быть проблема подÑкажите ранее Ð¿Ñ€Ð¾Ð±Ð½Ð°Ñ Ð²ÐµÑ€ÑÐ¸Ñ Ñ€Ð°Ð±Ð¾Ñ‚Ð°Ð»Ð° иÑправно (переуÑтановка программы Ñ Ð¾Ñ‡Ð¸Ñткой кеша не помогла, Ñмена винды и драйверов тоже не помогает )
Ðе работает одновременно клавиатура или мышь
Hello! If you want to turn your mouse and keyboard into a virtual controller, then you also need the Advanced Mapping feature. Without it, you won't be able to configure the mouse as a joystick, that's why the config doesn't work.
More details about the feature and its functionality can be found here.
To buy a feature, follow the steps:
1. Log in to your personal account. Use your email as a login
2. Click Customize button near reWASD
3. Check the feature
4. Proceed to Checkout
RAM Stealer i bought that one as well i bought licence and i could play with my mouse and keyboard + i put the config there and was good ) i played a little bit then i turned off ... affter that i go online again and tryed to turn it on but only my mouse not working he is not moving only ctrl alt del helps to turn it off i mean the rewasd progg and then my mouse working but not when it is on . then i saw that i should buy advanced mapping feature and i go on the site and bought it as well but same think help pls
