I have an Xbox One controller and am using it with Mount And Blade Bannerlord for months, but I see a notice, "your device is not supported" at the bottom of the screen. Why? I am using v5.8.1 Any help will be appreciated.
Device is not supported
Please try the clean reinstallation first. Here are the steps:
1. Go to Preferences (a gear icon at the bottom right), General tab
2. Click Clear data button and confirm your action
3. Wait until the GUI and tray agent appear
4. Re-plug the controller and check how you see it now
If it doesn't help, please reinstall reWASD after the steps above. Uninstall it, restart your PC, install and restart the PC one more time.
