I got the software for games that don’t support controller and when I done with the software it doesn’t give back my mouse. I don’t know what am doing wrong
Help
Once you apply a config with a virtual controller, your mouse and keyboard should be blocked, because otherwise you will get a double input in a game, and it is unplayable.
You can switch between two inputs easily. If you are using our default PS4 Remote Play config or any other one that is based on it, you will just need to tap the Left Windows keyboard key to get your mouse back and tap again to switch to the controller mode.
There are a few other methods for this case, you can check them at this article.
It may be a chance that something is not adjusted properly in your config at the moment, so please use Ctrl+Alt+Del hotkey on your physical keyboard for the emergence stop: the remap will be turned off, and you will be able to get your devices back and check the settings
