I’m trying to play Valorant on my pc but everytime I’m done playing Valorant I’m not able to use my mouse anymore, no matter if I even turn off the remap software. My mouse doesn’t move or work but my keyboard only works.
Controller
Valorant works with only one keyboard and mouse input. In order for the game to see the input from the remapped stick, the mappings should be emulated on behalf of your physical devices. Right now, this behavior only affects the mouse, but you can choose both to be sure that everything works perfectly with this or upcoming game’s versions.
So, to resolve the issue you need the following steps:
- Ensure that you are using reWASD 5.7.1 version
- Go to Preferences (gear icon at the bottom right) → Input Devices tab
- Choose the physical devices you are currently playing with in the drop-down lists (1) and click Apply (2):
Screenshot
- Apply your Valorant config (or choose one of those we have in our Community and play)
