Map gyro to controller?
  • Map gyro to controller?
    hi,
    is there a way to map gyro to controller?
    I used onexplayer to remote play ps5 with rewasd.all working great except that some games required to use gyro.and most games like uncharted 4 actually only need very simple movement like shake the controller up and down.
    as the onexplayer don't have gyro, it would be very helpful if I can like map the up and down movement to right analog (for example). But I couldn't find it.
    pls help
    thx
    Currently reWASD is able to passthrough the gyro data to our virtual DS4 controller and to remap gyro input to something else.
    We are considering to add a feature of remapping "something else" to a virtual gyro in the future.
    Your request is noted. Thank you!
      yes, please make it soon, as I saw on some threads, it seems this feature has been requested long ago and always still in considering state :'(
      I want to be able to use just the controller of onexplayer directly to remote play so I can play handheld.
      If I have to plug in a controller, I could just plug in a ds4 or ds5 without rewasd, and then all running perfectly, but then I couldnt play handheld mode.
      No need to be too perfect/complex.
      just simulate shaking the controller left/right, up/down would be very helpful to play most games.
      For more complex, a few other games only require the controller to be rotate like steering wheel.
      That's it I think.
      Very few games would need full gyro capabilities.
      I hope this could help speed up for u bringing the gyro capabilities to controller that dont have gyro.
      thx very much
