Having issues with the left input.
  • Having issues with the left input.
    So as the title says I'm having issues with the left input. When I press the left on the stick it triggers another button and I'm not quite sure why, the program tells me it's binded to the left movement as it should be. Previously this had happened with the D-Pad on different software, but this time the D-Pad left input does work as intended. All the other directions on the D-Pad and Left stick work as they should. It is a switch pro controller by the way, anyone might know why this happens?
    Please send me the config file you are using. Right-click on its name and select [Open file location] to find the file.
      Thank you for the reply, I messed around a little and got it working afterall! If anyone was wondering what the problem was I believe the configuration just wasn't saving but it works now.
        Great news!
