I am very new to this program but for the life of me I can not figure out how to change slots with just a simple hotkey. What I am trying to do is basically have one slot with macros and the second slot act as a basic mouse. I have two different configs set up and I go to settings to apply my hotkey to change slots but absolutely nothing happens and it just stays on slot one not matter what hotkey I put in. I checked the help FAQs but I couldn't get a very good solution.
Basic Question: I can not figure out how to change slots with a hotkey
Hello! Please send a screenshot of your config and slot settings.
If you want to use one button to switch the config layout, then maybe the Shift layers are better for you?
