Hello.
I am trying to play Kingdoms of Amalur Re-Reckoning with an Xbox Elite 2 controller. Having sprint, roll and my two attack buttons set to the back paddles is very comfortable.
However whenever Remap is on I am unable to sprint while holding the stick in any diagonal direction.
The game requires the stick to be fully pressed in a direction for sprint to work, and for Left, Right, Up and Down it works fine, but diagonal directions cause sprinting to become deactivated. You can see my character change between a sprint and a jog continuously if I try to sprint in a circle.
If i turn REWASD off or don't remap anything the sprinting works fine. To me, this sounds like a deadzone issue in my REWASD settings, but I am unable to tweak the high, medium and low zones for my left stick in any way.
I have done the following:
-Force controller off through Steam big picture.
-Affect gamepad behaviour for games is checked.
-Lowered the low and medium zones so that the high zone takes up the majority of the x and y axis
Nothing helps. No matter what changes I make to the zones it doesn't affect the left stick in any way during gameplay.
Anyone have any idea why this would happen? Any help would be greatly appreciated.
