Autodetect not working properly?
  • Autodetect not working properly?
    I have a profile set up for autodetect to switch to the xbox one controller on certain games. Autodetect is checked and saved and for some reason the controller still uses xbox one controller on every game instead of just the specific ones listed in the associated apps. How can I make rewasd only change my dualsense to an xbox controller in certain games and not every game?
    Hello! Please specify how autodetect is configured and for which games. If you have added the game launcher to the list of applications, then the config will be enabled when it starts, regardless of the game.
    Please note that for the autodetect to work correctly, you need to set the checkbox and turn on the radar.
