reWASD and XBOX elite controller 2
  • reWASD and XBOX elite controller 2
    Hello there,
    I'm facing issues with reWASD and Elite controller 2.
    My aim is to use the 4 trigger at the back of the controller as extra buttons. I managed to create a link to keyboards keys (on notepad, the triggers are sending the proper letters), but its also triggering the "Y" and "B" buttons controller. I tryied to unmap all the triggers in xBox accessories Software but there is no change.
    Any idea?
    Hello! Please indicate the firmware version of your controller. You can check this in Xbox Accessories.
      Software version is 4.7.1872.0
        Please send a screenshot of how the paddles are configured in Xbox Accessories app.
          Please find the the image below
            And the config in reWASD : Click image for larger version
              Make sure that paddles are unmapped in Xbox App on every profile (I think there should be at least 3 of those).
                Done on all the profiles. Now it works.
                Thank you.
