Nice to meet you. I like fighting games and I'm using rewasd for fighting games. If you use the designated combo key while the stick is moving, the combo will not work. The combo comes out only when it stops still, but can the stick's movement be temporarily eliminated when the combo is pressed while the stick is moving?
Remove the joystick movement when using combo.
The full ignoring of the stick movement cannot be achieved in key combo. However, you can use the relative deflection in the combo itself, so the stick movement will not stop the combo.
More details about deflection types can be found in this article.
Hey there, dnpq6427 !
May I ask you to send me your config file, the one that has extra inputs while using it? You can whether upload it to the community and send me the link, or right-click the config name in reWASD, choose Open file location, and attach the config file to your reply here.
