White circle randomly appearing on screen?
In case the config is not applied and the issue you are facing with is still occurring, the issue cannot be related to our app, since the only graphical interface we use is the desktop overlay.
You can try disabling the overlay to see if it helps.
reWASD -> Preferences -> Desktop Overlay -> Uncheck 'Show desktop overlay'.
Still, if there is no config applied when the issue happens, the overlay should not be activated and as result, cause any issues.
