When I create a profile, there is always an image as a boxart. Can't I deactivate it, so that there is just the gray background?
Boxart without an image possible?
Hello! Thank you for your answer!Originally Posted by reWASDer View PostHello!
Unfortunately, the short answer is no — if there is no boxart, then reWASD adds a default image. I think you could bypass it if you add some blank grey image instead of the boxart — then it will replace the default image
I thought so myself with the blank image; I just wanted to check, if I perhaps overlooked the option somewhere. But Windows Paint is my friend and helped me out with a blank grey image.
I also want to clarify: I have nothing against the default boxarts, they are beautiful! I think they are perfect as default boxarts! But I am just missing an option to have no boxart, just a plain colour.Last edited by chair77; 18.12.2021, 21:21.
