Every time I start reWASD it crashes as soon the window comes up to allow you to select your config. Any ideas?
reWASD Crashing
Please ensure that you are using the latest version downloaded from our official site — it should be 6.0.1.5195.
If yes, please check if you have any errors in Event Viewer following the steps below:
1. Press Windows button, type 'Event Viewer', press Enter
2. Choose Windows Logs in the upper left corner, then choose Application
3. Check out the panel on the right side: there's a Find option. Click it, and type 'reWASD' to search for related errors
4. Once you find one or multiple events, please right-click them, and choose 'Save selected events...', and send them to us.
