Hello, I have created a config that maps the kbm to controller but double movement will not work as it requires a keyboard input in the configuration you guys have created. Is there a way I can set a specific joystick deflection angle when pressing a key on the keyboard? I have tried changing the relative deflection of a and d keys to emulate double movement but they have caused my character to stop running when changing directions.
Fortnite Double Movement with complete unmapped
Hello! You can add Double movement to any config that makes a virtual controller from the keyboard and mouse. For this, remove the Unmap
from the A and D keys. But in this case, the aim assist will probably not work, because the game will also register the input from the keyboard. I assume that it only works if you have an input from the controller.
