Rewasd Dualshock 3 boot up issue
  • Rewasd Dualshock 3 boot up issue
    Hello, i use rewasd with dualshock 3 wired. I have rewasd set to boot up with my computer and i always leave the last config i use on. For some reason whenever i start up my computer the controller led lights flash normally and as soon as rewasd boots up, the lights turn off and the controller doesn't work unless i replug it. When i replug, the DS3 slot 1 led turns on and the controller works normally. The DS3 is recognised from rewasd regardless, it just doesn't work when i first turn on my pc unless i replug. Any suggestion? It's a minor issue for me but i'd like to know if there is a way to fix it. Thanks
    We have previously discussed this topic on Facebook, but this time I have some good news. We seems to be found a workaround for this issue — if we reset the USB port after the PC wakes up after the fast boot, all the buttons are working properly without the necessity to re-plug the device. Will add this fix to the upcoming reWASD version.
