just got this controller having issues getting the four rear paddels to work. was wondering if there are setting i can change or a way a can run it as an xbox elite controller. i can only get it to work as a pro switch controller but no option to map the paddels. if anyone can point me in the right direction would be very appreciated thanks.
PowerA Fusion pro switch controller issues
Unfortunately, reWASD is not able to detect the additional buttons/paddles, since they are not reported to Windows as separate controls, unlike Xbox Elite 1 and 2 paddles.
At the same time, a workaround has recently appeared that can help in remapping additional buttons of other controllers using their native software. We cannot guarantee success, but you can try this method.
