right stick control not working
  • right stick control not working
    I'm using a papapp trial license.
    In apex, right stick control does not work for me
    There is a chance that the devices are not initialized correctly, please follow the steps in this video to check the Device initialization.
      I have all devices initialized normally
        the keyboard works fine, but the mouse does not
          Check if your trial for Advanced Mapping feature is activated.
          Also sent a screenshot of your config for the mouse.
            Advanced mapping is off
Name:	экрана 2022-01-22 165751.png
              Thank you.
              The issue arose due to the fact that the trial for the feature ended. More details about its functionality can be found here.
