Trial Issue
  • Trial Issue
    Hello, I just discovered Rewasd and was trying its trial version. I was testing different games with keyboard and mouse via Ps Remote. Controls were fine in Uncharted, but choosing the inventory wheel in Diablo 3 was a bit difficult because the wheel wouldn't stay where it was. But my main problem was that Advanced Mapping and Rapid Fire were turned off even though the trial was 10 days away. But without these features, the test doesn't make much sense to me. Because those are the features I want to test. What is the purpose of these features ending before the trial process, I could not understand. There is no way to solve this so I can continue testing the program?
    The base license has a trial period of 14 days, while the trial period for each feature is 3 days.
    Send us your SID, we can extend the trial a bit.
      Thank you, I sent you a DM.
        Hi, if you haven't received your trial renewal yet, you can send your SID to me.
          Sure, I am sending it now.
            We have slightly extended the trial for your additional features so that you can fully test reWASD.
            In order to update the trial for additional features, click on the "Refresh the activation status" button in the "License" section.
              Yes it is updated now. Thank you!
