So at some point in reWASD i made a config for fixed directional influence on my controller to mimic the combined "wasd" on my left analog's input directions. Eventually, I uninstalled reWASD, but about 2 months ago my controller started having issues. Strangely this issue actually "lessens" the more i use it. (roughly 30mins-1hr). It got so bad i actually repurchased reWASD to see if their were and profiles still in there so, I could try to undo it. Everything in the application was completely reset. I contacted the "Helper" in the reWASD discord and deleted any remaining traces of the software including the vigembus we found. The problem still persisted. I have never touched another controller modder software outside of reWASD. I've tried in vain to fix my controller for the last week. When I tested different USB ports, the problem persists the same. When I use different xbox one controllers, they watch have their own level of variances of this weird stuttering deflection.
However, it came to my attention that one of my controllers I used before i switched to mouse, has remnants of a config on the right analog. This controller is barely affected by the weird left analog deflection. But, possesses its own deflection in the right analog which i made before the left analog config. I know its not mechanical since its occurring across multiple controllers. I've updated my GPU, CPU driver, controller driver (uninstalled-restarted computer), reset my bios, completely wiped/reset my windows, deleted most things in the files that i have access too and, checked for corrupted memory in my sticks (which passed). If anyone has any other ideas then, I would be glad to hear them and try them out.
I dont know if i can post links in here but, if i can ill post whats visually been happening.
