Need help with a deadzone issue
  • Need help with a deadzone issue
    So I’ve been trying to figure this out but I can’t, the issue is I’m trying to get my deadzone on my analog stick lower, some games like call of duty have deadzone options built into the games controller settings and others don’t, I’m playing farcry 6 and it feels like 20% of my analog stick movement does not get registered in game, is there any way to lower that? I want to keep everything about the controller settings default but I just want to change this deadzone setting, what setting let’s me change the deadzone setting to maybe 5% or lower, I don’t really care about stick drift, I just want some of these games feel responsive, thank you~
    Hey!
    You can change the Deadzone size in the Advanced Stick Settings.
    Click image for larger version  Name:	LmGKbD7Sgxe3Jm.jpg Views:	0 Size:	103.5 KB ID:	230205
    Try making the gray circle smaller and see if that helps.
    Also don't forget to enable this checkbox.
