Since this last update, I've noticed buttons aren't unmapped even after exiting the program completely.
reWASD does not unmap after exiting from software
Exiting the app does not disable remap functions, as remap is done via always running system service. reWASD is designed to work like that.
You can disable remap manually by clicking [Remap is ON] button on every device or by pressing [CTRL]+[ALT]+[DEL] shortcut.
It is also possible to remap any button or shortcut to [Turn remap off] command, though Tray Agent is required for it to work and it will disable remap only for device or group of devices that has this mapping.
