I wanted to change the right analog stick button to act as ESC but when i move any other stick or press a button, they all become ESC
Mapping 1 button to act as ESC, now makes them all ESC
I assume a few excess ESC keys were added to your config, and so you get the same mapping for different controls. Please try the following:- Go to Preferences (
at the bottom right) -> General tab and uncheck Hook controller buttons option and click Apply at the bottom right
- Create a new config, it would be better to start from scratch
- Add only the mappings you need — ESC for the stick, then add other mappings you need. Without Hook controller button option, you will need to press the button on the controller manually in the app, but in this case, you won't spam with ESC and they won't be assigned to other controls accidentally.
